Dummy Load setup?
I have antenna 8 connected to the dummy load. In the Antenna Settings it is Custom 1 and has checks in None RX and RX and TX on the line for Custom 1. Should I check RX and TX for every band the radio can tune to, or continue to leave them blank?
    Hi Jim, I assume that you are talking about an Antenna Genius connected to a Flex 6000, 8000 or Aurora radio.
    Here is how I have my dummy load set up on my 8x2 Antenna Genius:
