Fh3 Mike not working
I received the Y cable adapter and the bag has the correct name but the adapter doesn’t look like what you show here. Mine the female plugs are both labeled the same with the image of a headset with a boom Mike. It looks like it is a splitter for two headset boom Mike sets. Could it have been mis packaged. It doesn’t work plugging the Mike fh3 into either plugs. The ptt keyer adapter is working and keys the radio but no audio is being sent. Ya need the ability to post pictures.
I have the same issue: the Maestro will key and show transmit on both the Maestro C and the Aurora, but no carrier. It will tune and show transmit, but while using the FH3, no audio is sent. Did you find the "fix"0
The y cable they sent me was wrong. They’re sending me a new one. The correct one.0
I, for unknown reasons, was sent two Y adapter cables with my new Maestro C. One had one arm of the "Y" labeled with the picture of a microphone; and the other labeled as a headset. The second "Y" cable had a headset icon on both arms. Neither cable works! This raises the question "did firmware 4.2.20 introduce a new bug"?0
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
