ANT1/ANT2 Auto Switch works on Maestro or SmartSDR, not via CAT
IK2HKT Stefano
FLEX-6300 CAT band change does not trigger RX/TX antenna auto-switch.
I have a FLEX-6300 with RX/TX antenna settings on slice A and configured as:
- ANT1 = 10–160m
- ANT2 = 6m
When I change bands from the SmartSDR or Maestro, antenna switching works correctly:
- 40m to 6m = ANT2
- 6m to 40m = ANT1
When I change bands via CAT (using Logger32 or WSJT-X or N1MM or QARTEST ), the RX/TX antenna does not follow band settings:
- 40m to 6m stays on ANT1
- switch manually to ANT2 on 6m
- 6m to 40m stays on ANT2
- switch manually to ANT1
So I must manually change antenna each time I move band with any CAT.
Is this expected CAT behavior (frequency change only, no full band-change event for ANT logic), or is there a known setting/fix ?
73 - Stefano IK2HKT
changing via CAT does not do a band change but rather frequency change.
73 Dave wo2x
