LAN connections
I just received a PG-XL amp to go along with my 8400M. I currently have my 8400M plugged directly into a port on my windows pc.
I have seen some posts and also seen in the Quick Start Guide for the PG-XL, the use of a multi-port switch for all of the LAN access.
Should I be plugging the LAN cables from the radio and amp into a switch and then into the pc?
  • VA6SZ
    VA6SZ Member ✭✭
    The last sentence should read: Should I be plugging the amp, radio, and pc into the switch that goes to my modem?
  • Erik Carling EI4KF
    edited July 2
    Yes providing there is a router networking all together and allocating IP addresses.
