TGXL and AG ?'s
David43
David43 Member ✭✭
Hi David De Coones or anyone that may address my questions below,
David, thanks for the clarification on the number of memories TGXL has per band per antenna.
1.) The other day you told me to do a quick select/unselect of MOX before doing what (I forgot), please advise what that was for.
2.) Also, when setting up for Diversity Reception, I noticed after selecting SO2R that the Antenna Genius utility showed in the "A" column that my Hexbeam was selected, but in the "B" column my Vertical was shown in the center column but not showing that it was selected as the second receiver with a small solid red circle, why?
David, K1MT
  • David Decoons, wo2x
    by default the Antenna Genius will not let you select the same band for port A and B. This is to protect the radio from RF overload. If you have the proper isolation and free space separation between antennas, you can uncheck Inband Protection.
    AGAIN BIG WARNING about two antennas to two inputs on same band. It can cause damage if signal is too strong.
    The MOX before TG TUNE was when the alternate radio is going to tune. The MOX on/off causes the TG XL to switch to correct side before TG Tune is pressed. Otherwise you will get NO BAND DATA.
    73 Dave wo2x
