DVK Digital Voice Keyer recording length
I just upgraded to v4.2.20 and the length of recordings is only 10 seconds. The release notes indicated 30 seconds would be available. What am I missing?
K4GSR
David
  • Eric-KE5DTO
    David,
    Can you point me to where you see that in the release notes?
  • KA4GSR_David
    KA4GSR_David Member
    I can't find it now. Maybe I misread. I was looking forward to recording the preamble of several nets that I run. 10 seconds isn't enough time for that.
    Hi David, take a look at Audacity. It is easy to set up and use.
  • Neal Pollack AB6G
    Neal Pollack AB6G Member ✭✭
    edited June 15
    I also noticed this 10 second limit, which makes the voice keyer of limited practical use.
    Most CQ recordings that I have used with Voice Keyers over the last decade tend to be in
    the range of 15 seconds for normal CQs (Long enough for someone to notice and
    tune in), and up to 24 seconds for special event CQs.
    Personally, I would rather have fewer voice keyer slots that are longer, rather then more
    slots that are only 10 seconds long. For this reason, I have not been using the DVK
    feature. I was hoping it would arrive with capabilities more in line with the competition.
    Neal
  • petel22151
    petel22151 Member
    I agree with Neal ... fewer slots in exchange for longer times would be better ... up to 30 secs ideal.
