Green Herron R-21 and SmartSDR for IOS - Tool
ewetherill
Member ✭
I am unable to connect the GreenHerron tool to the GreenHerron. I amusing a ROBI router and tried to manually configure port forwarding. I can set 6555 as UDP but dont know what to do with HTTP 80
I have the same issue with iOS. I have not been able to connect it using the mobile devices but it does work on MacOS.
This might be a Marcus issue that he has to help resolve in SmartSDR for iOS or Green Heron.
I would like to see if anyone else has used it in iOS for iPhone or iPad and does it work for them
Marvin0 -
I think it is in how to port forward. Green Herron has HTTP 80 which i cant find a place for in my router settings. There is a place to set the IP # and the UDP 6555. Also in smartSDR there is a place to set the IP# and 6555 but not the HTTP 800
