Flex radio and MARS ALE
I recently read a thread in which a member stated MARS ALE will not work with Flex radios because of scan issues. Does anyone have a direct experience with this? I was recently encouraged to discontinue using Flex radio with tuner genius and power genius.
Afternoon. get ahold of your region mars training officer. they can help/ or check us army mars.
I have never had any issues using flex.
try this:
Spanky97 - Does ION2G support remote Flex-6400/6600 using SmartLink? What about Maestro C? Note that I posted these questions ov3er there and I'll see what they say :-)
My 6400/6600 are remote
from Ion2g documentation:
What do you need to use ALE?
Transceiver
Normal or Hybrid ALE stations should use a modern CAT capable transceiver, capable of scanning without
the use of mechanical relays. Ion2G supports a number of transceivers natively, with additional
transceiver support via the use of FLrig. SDR transceivers such as Flex also work, though still require
additional manipulation.They do not provide any details on what "additional manipulation" means.
