Help w FLDIGI plz
I am at my wits end with FLDIGI. All my other stuff, wsjtx, gridtracker, jtalert, log4om, it runs fine. I can see there is communication with the radio as the signal strength (lower right) bounces in time with a CW signal. But the program will not assume CAT control. I have followed Ken Wells recent article (And Mikes video) on setup multiple times. It SHOULD work. It does not. Someone PLEASE tell me what I am missing here.
  • Gary NC3Z
    Gary NC3Z Member ✭✭✭
    Any reason you have not enabled this?
  • Gary NC3Z
    Personally I use HamLib and TCP/IP CAT control.
  • David (AA9G)
    David (AA9G) Member ✭✭
    edited February 15
    Dang it. I KNEW I would feel stoopid. Yeah the reason is I never saw that little button sitting there in plain sight. Thank you very much, Gary. Tell me, why do you use the one over the other?
  • W2ECK
    W2ECK Member ✭✭
    Having similar issue - using v4.2.18 - receiving fine but when Fldigi goes to TX - getting no power out . So tried the Hamlib setup in above screen shot - 2x checked - all settings the same. But still no power out of radio
    Ideas??
    73 Paul w2eck
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    Make sure you have the DAX button on , this enables the DAX TX ..
  • W2ECK
    W2ECK Member ✭✭
    Dudley
    Good morning. Yes I have checked that and it's on. This morning it's working. But the last several days it's been intermittent. It will work in the morning and I try several hours later and - No Power out - frustrating.
    73 Paul w2eck
