Does APF work for you in V4.2.18?
PhilM
I tried using APF and it sounds like it doesn't do anything, if it does, its so subtle it sounds like nothing going on with it.
Maybe its just me
same here unfortunately :(
Phil (and F4BPO): Thanks for reporting this. A few questions to be sure I'm using the same setup:
Are there any other DSP/noise mitigation options enabled such as NR, WNB, etc?
I am assuming you're in CW since this is the only mode where APF is enabled. Can you confirm which version you are using and whether you had a better result in a previous version (and which version that was)?
Which radio model are you using?
Thanks for any additional information you can give that may help us isolate this issue more quickly.
- 394 Community Topics
- 670 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 79 Aurora
- 319 FLEX-8000 Signature Series
- 982 Maestro
- 953 Genius Products
- 350 Tuner Genius XL
- 129 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
