Connecting Flex 8600 w/ 4.2.18 to KPA 1500 Amplifier Sampler for APD/SmartSpeech
Bill Roberts
I have a Flex 8600 with 4.2.18 loaded. I'd like to connect it to my Elecraft KPA 1500 amplifier to take full advantage of Adaptive Pre Distortion/Smart Speech.. The amplifier has the required -60db sampling circuit. I also have BNC cables to make the connection. Before connecting and 'trying it,' I'd like to find Flex documentation telling me how/when to connect and how to set it up in the software.
Thanks and 73 de Bill K8DXX
Thanks. I'll try it as soon as I get off the Flex Net. 73
Hi Bill, it is a very simple setup. The -60 dB tap to RXA, RXB, XVTRA or XVTRB. Then in Settings, Radio Setup, APD tab, select the RX antenna port that you connected the RF tap to. Enable APD and you are done!
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
