WSJTX config with Flex CAT Control
LA9KY
LA9KY Member ✭✭
Hello,
I can not get the CAT working on my MacBook Pro, I get sound/decode working with DAX Streaming.
In wsjtx config is
Radio FlexRadio 6xxx, CAT, Data/pkt, Rig
Network server 127.0.0.1:5005
CAT control 1
enabled Type FlexRadio CAT, port 5005, Status connected
The wsjtx Test CAT, sometimes goes green, sometimes Hamlib rig error.
Hitting the Tune or initiating a CQ, take’s maybe 2-6 seconds before transmitting.
Band change from wsjtx very unstable.
WSJTX v3.1.0 improved plus edition, just upgraded from 3.0 (also with problems)
Currently Mac is on same LAN as radio.
Anyone operating wsjtx using Flex CAT ?
  • Henkka
    Henkka Member ✭✭
    Hi Frank,
    Try using Kenwood TS-2000 CAT. I had similar problems earlier, but since I changed to Kenwood TS-2000 CAT protocol WSJTX has been working flawlessly. I hope it works for you.
    Best regards,
    Henkka OH5KNL
