Connecting Flex 8600 w/ 4.2.18 to KPA 1500 Amplifier Sampler for APD/SmartSpeech
Bill Roberts
I have a Flex 8600 with 4.2.18 loaded. I'd like to connect it to my Elecraft KPA 1500 amplifier to take full advantage of Adaptive Pre Distortion/Smart Speech.. The amplifier has the required -60db sampling circuit. I also have BNC cables to make the connection. Before connecting and 'trying it,' I'd like to find Flex documentation telling me how/when to connect and how to set it up in the software.
Thanks and 73 de Bill K8DXX
Hi Bill, it is a very simple setup. The -60 dB tap to RXA, RXB, XVTRA or XVTRB. Then in Settings, Radio Setup, APD tab, select the RX antenna port that you connected the RF tap to. Enable APD and you are done!
- 393 Community Topics
- 669 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 74 Aurora
- 318 FLEX-8000 Signature Series
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
