PC mic source reference level for third-party clients - what SC_MIC level drives full SSB modulation
I'm working with a third-party SmartSDR client on Linux and
trying to understand the expected audio reference level for
the PC mic path (remote_audio_tx).
Empirically I've found that SC_MIC (meter 26) needs to peak
around -3 to -5 dBFS with mic_level=100 to reach rated PEP
on SSB. At SC_MIC around -12 dBFS (which appears as a nominal
level in some documentation) I only reach about 75-80% of
rated power.
A few specific questions for anyone who knows the firmware
signal path:
- Is there a documented target level for PC audio arriving
at SC_MIC that produces full modulation depth without
triggering the SW ALC? Or is the expectation that
mic_level gain compensates for whatever the client sends? - Does SmartSDR's PC mic path apply any internal gain or
normalization before sending the VITA-49 stream, beyond
the raw int16-to-float32 (divide by 32768) conversion?
In other words, does SmartSDR send a hotter signal than
raw 0 dBFS = 1.0 float, or does it rely on mic_level
to do the scaling? - The ALC meter (post-SW-ALC) shows -6 to -9 dB of gain
reduction during normal speech at these levels. Is that
a reasonable operating point, or does it indicate the
input is too hot?
Context: building a client-side TX DSP chain (compressor,
EQ, limiter) and need to know the correct output level
target so the chain's ceiling and trim settings are
calibrated to the radio's expectations rather than found
by trial and error.
Radio: Aurora AU-520, firmware 4.1.5.
Thanks for any insight.
Depending on which 3rd party client you are talking about, you might have better luck asking them about your issues. There's a thread here for AetherSDR and another for RemuSDR that you might want to check to see if there's any information posted there that can help you.
Thanks James, appreciate the pointer. 😀 I'm active in several communities already.
To clarify: my question isn't about a specific client's behavior -- it's about the radio's firmware signal path. Specifically, what SC_MIC level the radio's TX chain expects for full modulation depth on the PC mic input.
Any third-party developer building a SmartSDR-compatible client needs this information to calibrate their TX audio output correctly. Right now the only way to find it is trial and error with a wattmeter, which is what I've been doing.
If anyone from FlexRadio or with firmware knowledge could comment on the three questions above, it would benefit the whole third-party developer ecosystem.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
