Can't get JTAlert to work after upgrade to V4.2.18
Dale, W5OG
Member ✭
No problems with upgrade, and making necessary changes to get WSJT-X to work with DAX V2, however I have been unable to get JTAlert to work. It was working fine logging to N3FJP's AC Log before upgrade. Is there something else that needs to be changed, or is JTAlert perhaps like Slice Master and not compatible with V4.2.18? Has anyone successfully managed this after the upgrade and did you have to do anything special to make it work?
Best Answers
I did not have to make any changes in JTAlert when migrating between 4.1.5 and 4.2.18.
Check under logging in JTAlert you have ACLog enabled and the default port 1100 selected. Also in ACLog under the API section of settings the bottom section for port 1100 should be enabled. (Not in front of PC now).
73 Dave wo2x0 -
Thank you Dave. I got it working all OK last night. Not sure what I changed to make it work, but all normal now. What is the status of Slice Master?0
