How to assign a Maestro F-key to toggle "Breakin"?
Steve K9ZW
Steve K9ZW Member ✭✭✭
How do I set up an F-Key to toggle my Maestro-C's "Breakin" function?
Fairly simple task that otherwise is a couple menu levels down that should be one's fingertips.
Or did I miss it?
Steve K9ZW
Blog: http://k9zw.wordpress.com
  • Trucker
    Trucker Member ✭✭✭✭
    I don't think that is a function that can, currently zbe assigned to one of the Function Keys. You might try adding this in the Ideas section as a feature request.
  • g4ivv
    g4ivv Member ✭✭
    Hi Steve,
    I think James is right, that's not curretly possible. However the workaround I use when I want to do a bit of CW parctise or warmup is to just tap whichever slice TX button is litup red. With no TX enabled on any slice I can do my CW warmup excercises with sidetone coming fron the Maestro.
    Prior to SmartSDR release 4.1.5 there was a bug that meant if you changed the CW keyer speed whilst the TX was disabled, the sidetone would stop but that appears fixed for me in 4.1.5.
    73, Jonathan
  • Steve K9ZW
    Thank you WD5GWY and G4IVV for quick replies.
    I have posted in "New Ideas" a request to add "Breakin" to the Maestro F-Key options.
    As a CW-learner I'm often doing echo-back practicing, and would hate to make the world suffer with my "learner's fist!"
    Steve K9ZW
