Older type FPU Fans for Flex 6700, 6500, and I believe 6300
I have surplus to me several NEW ADDA AP0512HX-J96 Fan's for the Older Flex 6000 series Radio's and a few NEW Original part number Chassis Fans.
Reason I'm selling these is because I sent my F6700 in for a Spa Day and they changed out all the Fans with the newer style fan's so they will no longer work for my Radio's.
Some of these have the three hole Molex connectors and some don't but are easy to swap with your original Fan connectors.
With these you can simply remove the 4 Philip's head fasteners holding the Fan motor and Blades on the heat sink and put the Molex plug from the old fan on the NEW fan wires with solder and small heat shrink and use the same 4 Philip's head fasteners to remount them to the heat sink and plug it in.
If anyone want's to purchase these new fan's contact me at "wx7y_at_wx7y_ DOT_net".
Bret / WX7Y
Hi
have you two fans to sell would need it for my 6500.
73 de SB6A
Pierre Gassander
Gothenburg
Sweden
- 685 The Flea Market
- 195 SmartSDR+
- 102 Aurora
- 994 Maestro
- 971 Genius Products
- 357 Tuner Genius XL
- 133 Antenna Genius
