SO2R Operation
Can both ports be active on Antenna Genius Simultaneously?
Can both ports be active on Tuner Genius Simultaneously?
We have 2 machines (oen FLex and One Non-Flex) running FT8 on 2 seperate machines and they are on same odd interval. I understand obviously the PGXL can only accept one at a time. But what about if the TGXL was on standy ? Are both ports through on PGXL? And if one port is active on TGXL is other port on Standby / though ? Or is the signal impeded on the non TX side . Thank you
  • David Decoons, wo2x
    No, The relays for SO2R are designed so that when the amp and tuner are in circuit on the A side, the B side input to output is connected directly, bypassing the amp and tuner.
    If you set up a different radio on each port, they will both receive but one will have the amp and tuner in circuit and the other will be bypassed.
    You'll only be able to transmit on one radio at a time and you will need to have proper isolation between the two radios (free space between antennas) or you can damage the receiver of one of the radios.
