Flex 6600 & ALS-500M Setup
Trying to get an Ameritron ALS-500M working with my 6600.
Amp keys (it's in TX1), RF Power lowered to 30W in SmartSDR pane. Setting in SMartSDR are
Can't find a value I should be putting in RCA TX1 field so set to 1 (on?)
Power still seems low on transmit - I hear amp click though… I'm missing something obvious…
Thanks, Martin KW1M
    Hi Martin, the RCA TX1 field in Timings is a delay in ms, not on/off. For your purposes, it should be set to zero.
    How much power out are you getting for 30 watts in?
