Slice Fonts
Ippolito
Ippolito Member ✭✭
edited April 2023 in SmartSDR for Windows
because the slice looks like this
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    SmartSDR requires two special fonts: Didact Gothic Font and Napoli Serial Extra Light Font. Your symptoms suggest that it is likely those fonts, for whatever reason, are missing. They can be downloaded from the following link:
    https://www.flexradio.com/software/?_search_archive=smartsdr%20fonts
    Scroll down the list on this page and you will find them...
    73, Craig KØCF
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    edited April 2023
    @lppolito
    I have that same "chopped-off" frequency whenever I run Remote Desktop. It's very hard to read.
    That is, I have SmartSDR running on a (Windows 10 Pro) shack PC, and I connect via RDP either from my shack Linux box, or from offsite with another Windows 10 Pro machine.
    So, every RDP client displays these "chopped-off" frequencies as your picture shows. This "chopped-off" occurs on both the Flag, and also in the Panel.
    Flag:
    Panel:
    I never experience this if I am directly using the PC running SmartSDR (locally, or remote).
  • W4AFK Bruno
    W4AFK Bruno Member ✭✭✭
    Flex 6400 & SmartSDR 4.1.5 - I now have that problem even after I installed the two fonts I downl;oaded from Flex Radio. I installed (and reinstalled both fonts, rebooted the computer seevral times, restarted SmartSDR 4.1.5 every time, but the fonts are still cut as ahown above.
    This is a NEW problem as it all was fine 2 weeks ago. Now I have this issue and I cannot get it to use the proper fonts
    Hi Bruno, I would submit a help desk ticket.
  • timhofbauer
    timhofbauer Member ✭✭
    I had a similar issue with the frequency numbers in the pan adapter bar cut off. I put a snip picture in ChatGPT and it said I had the text size too large in the accessibility setting in the display settings.
    Correct Fix (Recommended): Use Display Scaling — NOT Text Size
    FlexRadio designed SmartSDR to work with Display Scale, not the Accessibility “Text size” slider.
    Do this:
    1. Right-click desktop → Display settings
    2. Under Scale & layout
    3. Set Scale to one of these:
      • 125% ✅ Best balance
      • 150% ✅ Works on most systems
    4. Leave Accessibility → Text size at 100%
    Do NOT increase Text Size separately.
    That’s what causes the frequency numbers to cut off.
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    Tim said:
    "I had a similar issue with the frequency numbers in the pan adapter bar cut off. "
    Tim, same problem here and your suggestion to set the Accessibility Text Size to 100% fixed the problem. It was at 125%
    Thanks…
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6600 SSDR V3.9.18
    TGXL 1.2.17
    PGXL 3.8.9
    Win11
  • W4AFK Bruno
    Hmm … It was at 100%. I tried 125%, 150% and back to 100% … still getting cut off.
    Both fonts we installed (and reinstalled), computer was rebooted (more than once), Windows confirms that the fonts are installed, but the text is still getting cut off (see image).
    Even the Settings | Radio Setup screens are cut off.
