Band pass filters in multi-radio environment
I haven't quite found the answer to my specific question. I will be doing small 2 radio expedition. The second radio, not a flex, will be running 500 watts and will have its own 150 BPFs between radio and amp. I will be running the AU520m. Do I need separate BPF's in this environment or are the internal BPF's in the Flex good enough?
The secondary issue is if I have to use external BPF's, i will need the big, high powered, filters which will take up too much space, since I will be running 500 watts from the AU520m.
Please advise.
Mike AD5A
    Hi Mike, the BPFs in the 520 should be more than adequate. They are 7th order filters good for 50 + dB of out of band attenuation.
