Commands for settings some filters fail
Hi All,
I can successfully read NRL, NRS, RNN, ANFL, and ANFT states from slice status messages (e.g. nrl=0, nrs=1, rnn=0). Changes made in Maestro are reflected correctly.
However, when I try to set them using slice “slice set 0 nrs=1”, the radio responds with error 5000002D.
Standard properties like nb, nr, etc… work fine with “slice set 0 nb=1”.
Is there a different command format for NRL/NRS/RNN/ANFL/ANFT?
Or are these not yet exposed in the public TCP API?
Running v4.1.5 firmware.
Licensed version: v4
Any guidance appreciated!
73!
All good, finally I sniffed all commands from SmartSDR using Wireshark. :-)
What was the fix?
To fix the issue, I used Wireshark to sniff proper commands to be send.
Any chance you might share these to save us some wireshark time?
No problem Gary. This is what I used in my app…
All commands use: slice set <slice_number> <key>=<value>AUDIO
audio_level=<0-100> Volume
AGC (Automatic Gain Control)
agc_mode=<off|slow|med|fast> AGC mode
agc_off_level=<0-100> Gain (when AGC mode = off)
agc_threshold=<0-100> AGC threshold (when AGC mode != off)SQUELCH
squelch=<1|0> Enable / disable
squelch_level=<0-100> Squelch levelNOISE BLANKER
nb=<1|0> Noise Blanker enable / disable
nb_level=<0-100> NB levelwnb=<1|0> Wideband Noise Blanker enable / disable
wnb_level=<0-100> WNB levelNOISE REDUCTION
nr=<1|0> Noise Reduction enable / disable
nr_level=<0-100> NR levellms_nr=<1|0> NRL (Leaky LMS) enable / disable
lms_nr_level=<0-100> NRL levelspeex_nr=<1|0> NRS (Spectral/Speex) enable / disable
speex_nr_level=<0-100> NRS levelnrf=<1|0> NR Filter enable / disable
nrf_level=<0-100> NRF levelrnnoise=<1|0> RNN Noise Reduction enable / disable (no level)
NOTCH FILTERS
anf=<1|0> Auto Notch Filter enable / disable
anf_level=<0-100> ANF levellms_anf=<1|0> ANFL (Leaky LMS ANF) enable / disable
lms_anf_level=<0-100> ANFL levelanft=<1|0> ANF Tracking enable / disable (no level)
PEAK FILTER (CW mode only)
apf=<1|0> Auto Peak Filter enable / disable
apf_level=<0-100> APF level1 -
Thank you! There were 4 of those that I couldn't get working and was trying to avoid using wireshark to figure it out. lms_nr , lms_anf, speex_nr, rnnoise.
Thanks for sharing!
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
