Commands for settings some filters fail
sq5x
in SmartSDR API
Hi All,
I can successfully read NRL, NRS, RNN, ANFL, and ANFT states from slice status messages (e.g. nrl=0, nrs=1, rnn=0). Changes made in Maestro are reflected correctly.
However, when I try to set them using slice “slice set 0 nrs=1”, the radio responds with error 5000002D.
Standard properties like nb, nr, etc… work fine with “slice set 0 nb=1”.
Is there a different command format for NRL/NRS/RNN/ANFL/ANFT?
Or are these not yet exposed in the public TCP API?
Running v4.1.5 firmware.
Licensed version: v4
Any guidance appreciated!
73!
All good, finally I sniffed all commands from SmartSDR using Wireshark. :-)
What was the fix?
To fix the issue, I used Wireshark to sniff proper commands to be send.
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 942 Genius Products
- 346 Tuner Genius XL
