Maestro-C Battery Charging
johnn1jm
johnn1jm Member ✭✭✭
I charge the battery inside the Maestro, not with an external charger. The battery indicator does not now go above 96%. It used to read 100%. Is this indication of battery aging? I don't use the battery much and it's less than a year old.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Well, it's back to 100% but took a long time to get there like a day.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    A sign of battery capacity diminishing.
  • W4AFK Bruno
    W4AFK Bruno Member ✭✭
    Mine is new and when I installed it it was at 30%. A couple of hours later it was at 100%. I agree with John that what you are seeing could be the sign of a battery getting worn out.
