Common Frequency Usage / URL Like Software?
I am certainly not referring to this properly in the subject …
Does a software exist that stores commonly used frequencies, like a URL of sorts, to quickly move around the bands. For example, storing favorite SWL stations, broadcast stations, TIME, etc.
Click on the stored frequency and go.
Take a look at the Memory function on the Flex, this is where you can store 'channels' with all the appropriate settings.
Also, I can't remember the name, but I believe one of our forum members also created a 'memory channel' app specifically to help out with repeaters (if you have a transverter).
Thank you Don. I did find the memory function. It would be nice to import frequencies :)
I am unable to locate the 'memory channel' app.
It was one developed by someone here in the Forum — specifically for those wanting to store 2m repeater frequencies, offsets, etc. I'll take a look around and see if I can find it.
FRStacks (I think the latest version is 4) also has a more robust memory function.
The other one I was thinking of is KD0RC's Flex Repeater Spots, but this may not be what you were looking for.
Second the above. FRStack stores many more parameters, is easier to access and update plus many additional features. Flex profiles are kind of kludgy, sort of an engineers solution rather than an operators solution.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
