Help with DVK
I'm trying to get setup for the ARRL DX SSB contest this coming weekend. I have a Flex 6600 running version 4.1.5. I just paid to use the DVK upgrade in Smart SDR. The .wav files are loaded and playing correctly but after each file is finished, the MOX button is stuck in the on position! I can't get it to turn off except to manually push it. I'm operating remote and will be using VOX. Also, are there CAT commands for the DVK that can be used in N1MM to trigger the DVK messages in N1MM?
Thanks and 73,
Kevin, N5DX
Hi Kevin,
check what time is displayed for the file in DVK.
Once you have edited the files or if you did not release
the PTT immediately after recording, the playback time
may be longer than the content.If you set an end mark in your Audio software and save the file may be the old length will be retained.
Only if you save the selected area will the time be shortened.
At least that's how it works for me. I use Goldwave73 Klaus
Thanks for the response Klaus.
The stuck MOX is only occurring on the F2 message on the Flex DVK. I've tried dozens of times playing F1, F3, and F4 and the issue only occurs on the F2 message. I've tried different messages on the F2 and still the MOX sticks. The problem is repeatable.
I can work around the F2 problem, but I'm really hoping someone can help out with macros to use from N1MM to trigger the Flex DVK to play.
Kevin, N5DX
- 650 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
