6400 + 4.1.5 crash on memory select
Selecting a memory results in SSDR freezing, then crashes followed by the start screen "disconnect"? Sometimes the "Connect" screen follows and trying to connect works for a very short time and crashes. Cycle repeats. S/D of 6400 and restart clear it all up until I tried manually typing in a frequency (11175) then freeze and crash.
Event Viewer gives me a long list of exceptions that I cannot interpret. EV also listed .Net one second prior to SSDR crash.
W11 is up to date as is .Net.
Can anyone replicate - assuming I haven't totally confused everyone.
Hi Lionel, if you haven't already, export your profiles and do a factory reset. If that doesn't help, submit a help desk ticket.
Thanks Len for suggestion. I'll try this and I suspect this will fix the issue. If not - Help Desk.
N5LB Lionel
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
