SliderMaster - DSP Sliders - utility to adjust DSP levels
Good evening.
Is there any chance I could join the testers? Thank you. EA1DR Oscar0 -
Heads up beta testers, going to do another beta release in the morning. Need some sleep and do some testing before I upload the v1.13
*********************** V1.13 Beta *********************** pending release
- MORE feature, Bonus Features, Xtra Feature, whatever the name will be is being worked on.
- Added Record/Play - Bonus Feature
- Added DAX- Bonus Feature
- Fixed when slice selected only the DSP features for the current mode are available as should be.
- Changed method to show active slice in the slice Window, the frequency color now indicates the active, and is user defined in Preferences.
- Added mute speaker beside slice to make it easier to mute/unmute slices.
- DSP level value beside slider removed as redundant since the tooltip bubble show the same when mouse is hovered over the slider
This should be one of the last, if not the last release for beta testers. If I don't get any major issues brought to my attention by testers, I plan to do release for all Wednesday the 18th. Development continues for MORE - Bonus Features.
*********************** V1.13 Beta **************************** released Feb.14th
- Fixed issue with TX slice on client being turned off when SliderMaster starts.
- Added slice mute speaker beside each slice letter & slice box.
- DSP levels now show in bubble when mouse is hovered over the slider
- DSP description shown when hovering over DSP button.
- Minimize window feature put back .
- Added screen position persistence, for About, Help, FAQ and Preferences.
- Added RX EQ, loads current RX EQ per selected profile. - Bonus Feature
- Bonus Feature free preview for set time of 10 min. then have to OK, and open MORE again.
- MORE, the Bonus Features without timer, is available to those who donate!.
- Donation, validation process added.
- PGXL, TGXL and AG detection for future use.
- Not Fixed, adjusting EQ levels changes TX EQ, it should change RX EQ!!!
- Not Fixed, adjusting RFgain does not actually change RFgain, yet.
*********************** V1.15 Beta **************************** released Feb.16th
- Fixed client TX slice being removed when SliderMaster starts.
- Added TX select by clicking on the desired TX slice.
- Added Frequency and mode to top of Active Slice area.
- Added, feature to change 1hz, 10hz, 100hz and 1000hz using MouseWheel, (similar to PowerSDR), by moving mouse underneath the digit, then use MouseWheel up/down.
- Fixed "Change slice Frequency, MouseWheel up/down" when hover over NR.
- Fixed slice vol, pan and agc mousehover showing when not suppose to.
- Fixed Name in Preferences not showing after being saved.
- Added new buttons and new Black, DimGray themes.
- Added to Preferences, ability to select Volume Color.
- Added see changes immediately when changing: Theme, Volume Color, and Active Frequency Color.
- Added toottip detailed caption for each DSP from Ken Wells that suggests the best scenarios to use each DSP. See FAQ for Ken's full technical reference.
Hi Mike,
For some reason, when I click MORE to show the additional features, everything goes away accept for the title bar of the program.
Rich - N5ZC
Rich, what version are you using, I'm releasing v1.17 very shortly, later this afteroon is the plan.
Mike,
I've been staying on top of the upgrades. I 'believe' the problem started when I went from 1.14 to 1.15.
Rich - N5ZC
Make sure you uninstall the previous version, though v1.17 is coming out later today, install v1.16 and let me know. I do not have anyone else reporting something like this.
I'd like to do some testing as well!
TNX
R,R Mike,
FYI, I do an uninstall of the previous version first, then install the latest version.
Has anyone else noticed this issue, or is it unique to my setup.
In the mean time I'll qrz until 1.17 is released and we'll see if that solves the problem.
This would be a neat app to have sitting on a separate touch screen monitor next to the keyboard.
Rich- N5ZC
Rich, I've been able to duplicate the problem you reported on my 6700. Does not do this with 8600, so I should have asked you what radio are you using?
I was finalizing a few things for a release but then this, so I'll have to delay v1.17 for a day or two.
Mike,
I'm currently running an 8600. I do have a 6600 as well. (Both non-M) If you need me to test it I can get it hooked up in the next day or two. Too much going on today.
Rich - N5ZC
- 384 Community Topics
- 650 The Flea Market
- 150 SmartSDR+
- 263 SmartSDR CAT
- 288 FLEX-8000 Signature Series
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 801 Peripherals & Station Integration
- 142 Amateur Radio Interests
