Selecting a good Mic for 8600 - advise needed
Hi
I currently use an older Heil GM4 balanced mic with a wide and narrow element. TBH, I'm not very satisfied with it and I wonder if someone could recommend a better/tested mic brand/type.
I usually focus on DXing than rag chewing, so a cutting strong modulation would be the best for me. But having an option for rag-chewing would be nice, too.
I also try to finde a good UCB-C mic that was already successfully tested with Flex.
Any recommendations?
73!
Stan SP8S
Hi Stan… The Heil mics are pretty well regarded, so I'm wondering what you're looking for in a 'better' mic?
Using the TX equalizer, you can pretty well tailor almost ANY mic to your voice and/or the characteristics you want on your transmitted signal.
I have used a Heil 781 on Flexradio equipment for 7+ years with very good results.
Stan,
Before changing mic, try adjusting the TX eq. Multi uses can be saved as mic profiles.
First use cut before boost.
For DX cut 6dB or more above 3 k or so, maybe more. Also cut 64 off, and gradually cut the higher freq's in a sliding scale up to 512. There are multiple ways to assess the effects, but I am cautious about most of them. The DX stations don't care if they can understand you. Save it a s a DX profile. ,
Most people dont know what their voice sounds like to others so for rag-chew, just start with everything flat and safe it as a Flat profile.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
