Røde PodMic USB-C - no audio from Flex 8600 - help needed
Hi there
I need some help with setting up my microphone - Røde PodMic USB-C - which I successfully used for Icom and SDR-Control for Icom before. It was working with 7610 just fine.
I have no problem to use a balanced Heil mic with my 8600, but for a reason unknown, the USB-C mic, although it's visible in SmartSDR in available mics, does not produce any audio on SSB. I can see its levels in the Levels (above the Compression levels) when I select “Mac” from mic list below, while speaking to the mic. But it produces no output signal when I try to transmit.
Could you kindly guide me through correct settings to make it working, please?
Thanks in advance and greetings
Stan SP8S
Update, another Flex user experiences the same issue
https://community.flexradio.com/discussion/8033182/au-520m-smartsdr-and-no-transmit-power-output
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
