cannot close smart control window on maestro
Hey guys, I just got a new Maestro to go with my 8400 and while it seems to be working OK, as I can move the SDR frequency with the Maestro VFOand the SDR can move the Maestro frequency, I cannot find a way to close the smart control window. Any ideas here?
Bruce KO4UHL
  • johnn1jm
    johnn1jm Member ✭✭✭
    Answer ✓
    Panadapters waterfall will only show in SSDR on Mac or PC. Where it says station on the Smart Control Mode window I assume you have the name of your PC or Mac there that is running SSDR.
    Hi Bruce, when in SmartControl, you do not get the option to have the panadapter/waterfall showing.
  • Trucker
    Trucker Member ✭✭✭✭
    Bruce, you cannot close the Smart Control window while using the Maestro to control SmartSDR on your computer. You have to exit Smart Control to get back to using the Maestro to do everything with your radio.
  • Bru
    Bru Member ✭✭
  • Bru
    Bru Member ✭✭
    edited February 16
    Perhaps I should re phrase that question. Just got a new Maestro for my 8400 and installed it according to the instructions, leaving the SDR off at the time. I do not intend to run this radio remotely from another location. All I want to do is be able to use both the SDR windows 11 controls via Mouse and the VFO's on the Maestro to control the radio. I have changed setting on both quite a few times and I can get them to run separately, where the Maestro has no control on the SDR. But when I get them to work together, I am getting this screen on the Maestro…..SMARTCONTROL MODE. I remains blocking most of the screen and yet I can control the SDR with the Maestro VFO and vis versa. I cannot close this window. If I hit the exit at bottom left it just puts me in a loop that eventually brings me back to this same screen. What am I doing wrong here and how do I close this window? When I googled the question it came up with an exact duplicate problem that some people were having with an earlier version of the software and the fix was to go back to an earlier version. That was many versions and years ago on a 6400 and not today on an 8400, but the problem and photo was identical. Perhaps I should add that My computer, the 8400 radio and the Maestro are all hard wired in my network. I realize that there is something that does not jive between the Maestro and the radio, but I cannot find it. Does Multiflex have top be enabled to do this? Does FlexControl need to be on or off to do this?
    Thanks AGAIN Guys
    Bruce KO4UHL 73
    Hi Bruce, when in SmartControl mode, you do not get a panadapter on the Maestro or front panel. You only get the display that you show in your picture. This gives you mouse and keyboard control using SmartSDR on your computer while simultaneously being able to use the knobs and buttons of the front panel or Maestro to control the same slices.
    The way you have it is the way it works.
  • ka9ees
    ka9ees Member ✭✭✭
    Touch "Exit" in the lower left hand corner.
  • Bru
    Bru Member ✭✭
    Reply to all…..I cannot close the window in the picture. If I hit exit I just have to connect again and get the same screen. Its like a loop that never ends:-(
    Len, KD0RC
    I cannot use the Maestro controls if I can't close that window blocking everything. The VFO on the Maestro works and I can change frequency on both the Maestro and the SDR. How I close this window?
  • Trucker
    Trucker Member ✭✭✭✭
    Apparently you don't understand how the Maestro works with your computer when it's running SmartSDR. If you are wanting to use the manual controls on the Maestro to change VFO frequency etc, you have to use Smart Control. What you see on the Maestro at this point is a reflection of what some of the controls are doing in SmartSDR on your pc. The Maestro physical controls cannot control both SmartSDR for Windows and SmartSDR in the Maestro at the same time and allow for different changes between the two. What you can do is connect to the radio with the Maestro and control only what is displayed on the Maestro. And connect to the radio from your computer with SmartSDR and control a different panadapter using your mouse and keyboard with SmartSDR on your computer. In other words, the Maestro cannot control both at the same time. It is either or.
