Flex 8600 & Acom 1400S CAT connection
Hi there
I successfully (almost;) managed to connect Acom 1400S to my Flex 8600 using FTDI USB-RS232 converter cable. I see the USB cable in the Flex settings (set to CAT) and on Acom - I have green CAT connection to Flex. The only thing that is missing is the automating band switching, so that Acom would “follow” bands I select on the Flex.
I wonder can you guys advise me on correct Flex settings, please?
I'd be more than happy to get it working in 100%
73! Stan SP8S
Have a look at this, it's my way
https://community.flexradio.com/discussion/8031993/acom-1200s-amplifier-and-the-acom-04at-antenna-tuner-autotune-with-flexradio#latest
To transfer the frequency, the connection from the USB port of the 8600
to the ACOM PA is used via an FTDI adapter.Then go to SmartSDR under Settings, USB Cables.
Set the desired parameters for the ACOM: TX Slice, baud rate 38400, 8-bit, 0, 1, 0.
On the ACOM PA, set No. 5 for Kenwood.1
Hi Klaus!
You just made my day! I applied your settings, and it worked out just fine. Now, they "talk" to each other without problems and the PA follows Flex' frequency and I don't have to worry about any incorrect operating frequency. Thank you one more time!
PS. I will send this instruction to Acom in case they'd receive similar questions 👍️Best 73
Stan SP8S
Hi Stan,
It is my pleasure to have been able to assist you.
I started discussing the problems and my approach with Acom in the middle of last year.
Specifically, the autotune function for Acom's antenna tuners.
From what I've heard, they are working on completely new firmware.
But I think it will be a while before anything comes of it.
Please feel free to contact me directly if you have any questions. (om@df3rp.de)
Best regards 73 , Klaus1
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
