LOG4OM2 not showing correct RX value only the transmitter frequency value
Hello,
I asked the forum for LOG4OM2 if they had an answer but they didn't.
I have my Flex8600/SMARTSDR(v4.1.5) connected to LOG4OM2 using Omni-rig(v1.20). It works reliably well except that in split mode it doesn't recognize the two frequencies.
As a comparison I also have a FTDX101MP connected too, using Omni-Rig, and both frequencies are displayed here when in split mode.
So is my experience to be expected? or do i have a configuration issue?
Phil, NC3S
Hi Phil,
I just tried that and Log4OM only takes over VFO A, regardless of whether in split mode or as VFO B...
At least with the “Smartsdr.ini” file for Omnirig from W4TME.
What configuration are you using?73 Klaus
I just remembered that the configuration in Omni-Rig is not decisive.
This will unfortunately not work, as only one VFO can be set in the CAT for transmission via COM port to OmniRig.0 -
I was looking at that split mode settings, it has a SO2V setting. I tried that but nothing changed.
Yes, that doesn't change the situation that only one slice is transmitted via the interface.
We can only hope that Flexradio finds a solution so that two slices can be transmitted via one port. 😉0 -
Try switching to the hamlib version that's posted in the log4om forums instead of omnirig.
There is also a TCI option, but that looks like its specific for another brand of sdr. I will look at hamlib closer than i did before.
4.6 works fine here.
https://sourceforge.net/projects/hamlib/files/hamlib/
Hi Rick!
Are you using the COM or the network port?
It would be great if you could show us the SmartCAT and Log4om settings.
730 -
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
