WSJTX Transmit Audio Issue
Never had a problem until now running WSJTX. It decodes fine, but when it goes to transmit it keys the radio, but there is no modulation. I checked the settings on WSJTX, and they look correct. The only thing I see is that if I look at the DAX screen, I see DAX TX OFF. How did I turn it off, and how do I turn it back on?
THX in advance
  • DBC
    DBC Member ✭✭
    Answer ✓
    DOH! Somehow I closed that panel. Thank you
  • David Decoons, wo2x
    in SnartSdR for Windows, right side Phone panel.
    Also on Maestro or M model press the mic gain knob and enable in that menu.
    73 Dave wo2x
