SliderMaster - DSP Sliders - utility to adjust DSP levels
2»
  • Arapahoe
    Arapahoe Member
    Good evening.
    Is there any chance I could join the testers? Thank you. EA1DR Oscar
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    edited February 6
    Heads up beta testers, going to do another beta release in the morning. Need some sleep and do some testing before I upload the v1.13
    *********************** V1.13 Beta ***********************  pending release
    • MORE feature, Bonus Features, Xtra Feature, whatever the name will be is being worked on.
    • Added Record/Play  - Bonus Feature
    • Added DAX- Bonus Feature
    • Fixed when slice selected only the DSP features for the current mode are available as should be.
    • Changed method to show active slice in the slice Window, the frequency color now indicates the active, and is user defined in Preferences.
    • Added mute speaker beside slice to make it easier to mute/unmute slices.
    • DSP level value beside slider removed as redundant since the tooltip bubble show the same when mouse is hovered over the slider
