PGXL "SELFCHECK"
Hi, was operating my PGXL last night no issues… came back this morning to run it a bit and the software would not switch out of "standby" to "operate".
So I restarted the software few times, and no change, would not come out of standby…
So I went to the amp and looked at the screen, and it looked normal, but said "SELFCHECK" on the screen instead of "STANDBY". Everything else looked normal, so I power cycled the amp, all post tests were good and amp appears to be operating normally.
Question is if there is any insight on this? Did a search here and nothing to see… If I was remoting in, I would have had a problem as I don't have anything on the amp to cycle the 240V. (Not yet anyway, but thats not the solution)
Thanks for your time.
Mike - KM0T
  • David Decoons, wo2x
    Possible brown out? Drop in line voltage overnight? Just a thought…
    73 Dave wo2x
