Tuner Genius Not keeping tune
I have had my tuner for a while and have always had this problem. Never asked if anyone else has the same issue or any way to correct it.
When I auto tune it will get me down below 1.10 to 1.
When I further manually tune I can get frequencies down 1 to 1 or close. I save the tune by pressing the button in.
When I go back to that channel the tuner does not switch to the same settings I saved it to. Why is this happening. Is there any other way to lock in a tune so you can keep as low as possible.
I kind of wish there was a way to set the tune conditions manually for frequencies. Then would always be dead on.
  • Erik Carling EI4KF
    Glenn, you save the tune "by pressing the button in". Which button?
    C1 is the save button so I presume this is the one you mean. It works for me, not that I use it often so I cannot attest to its reliability. I just tried it, seems fine both when done physically and when clicking C1 in the Utility.
  • David Decoons, wo2x
    The difference in net output power from 1.10:1 to 1.01:1 is negligible. Not worth the extra effort.
    And remember, you only have 20 tuning memories per band. When you are ready to train the tuner across the band, switch to that band and press and hold the TUNE button on TG XL to clear old tuning memories first.
  • Glenn Depp
    Glenn Depp Member ✭✭
    I save the tune by pressing the C1 on the tuner. Shows saved.
    I have found it often does not use those variables. Some frequencies it doesn't even seem to try as the SWR can be 2.4, 2.7 etc so not even trying to tune to the minimum set SWR.
    I was unaware of the push and hold to clear. I will need to do that. What are the frequency ranges for each band. I am NOT only using this on Amateur Frequencies. I do other services as well.
  • Glenn Depp
    I went and downloaded the manual again. I did a full reset. I wen thru all of the frequencies I use. I was able to get tuned very well. The highest SWR on any channel that I tuned was 1.06 so I am happy with that, although wasn't my problem.
    Now that I ran through all the channels and tuned. I went to one of those frequencies I am about to have a net on and the tuner DID NOT move to the tuning settings I saved, in fact the SWR is 3.03 to 1. I have the tuner to use a minimum SWR of 1.10. The tuner does not automatically tune to get one without hitting the tune button, nor did it switch to the saved settings. AND when I hit the tune button it tunes down ONLY to 1.23 not the 1.10 it is set to. Not happy right now. I have had this issue for a long time but now I am very irritated.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Does the TGXL display the show the same frequency as the radio?
  • Glenn Depp
    YES it does
  • Glenn Depp
    New question about the tuner. If the tuner is set to always have no higher than 1.10:1 should it not automatically tune if higher than that setting? Mine does not.
    the Tuner Genius does not automatically tune if SWR increases. You must train the tuner.
    73 Dave wo2x
  • Glenn Depp
    ok. I did that. I even reset the tuner and went through every frequency getting swr 1:1 on all frequencies. I guess the issue is it does not always go to the preset variables that were saved. OK. Thanks.
  • Bill AB7AA
    Bill AB7AA Member ✭✭✭
    Glenn,
    If I understand your issue with the tuner correctly, I have the same problem. Every once in a while it forgets to go to the saved settings. Sometimes I can get it back by switching profiles, which is how I change bands, but sometimes I just have to retune it to get it to apply settings.
    Bill AB7AA
