Smartsdr not seeing Flexcontrol after reboot of windows 11 PC but does after Smartsdr recycle
Hello,
I've seen a number of similar issues being discussed but here's mine.
I normally shutdown everything at night, Flex8600 and windows 11 pc.
When I, usually the next day, I restart my PC and start my Flex-8600, 100% of the time my Flexcontrol doesn't function with SmartSDR v4.1.5. I then shutdown smartSDR and restart it, and all is well.
Even if I exercise the Flexcontrol before the first start of SmartSDR it doesnt work, but it always works after restarting SmartSDR.
Any Ideas as to what is going on? I suspect its a windows 11 driver thing, but being an oldtime mainframe systems guy I'm not sure. Its defined as com240. Its not a big deal shutting down and restarting but it seems odd to me? Note that Windows 11 can be up and running before the issue for hours and the problem occurs.
Phil NC3S
Ok got it fixed now. I moved the flexcontrol to a USB port I have on a board in a slot. I noticed that with this USB port now being used, when I plugged in the Flexcontrol a USB attached sound was generated, when I removed it, a USB removed sound was generated. The previous built-in USB port didn't make those USB sounds.
Being curious I asked AI, and it said that "windows wasn’t enumerating the FlexControl"
Its working now.
73 Phil, NC3S
Thats the first time ive heard of setting the comport at that high a number. Try deleting that and setting it at port 99. It will then be happier.
OK I'll give it a try. I originally set it to 240 at the request of flex support.
Thanks, Phil NC3S
I tried your suggestion this morning, there was no change. I was thinking about deleting the drivers then reinstalling them. But its difficult locating the drivers.
Maybe this weekend if all this bad weather hits the east coast I'll have the time to do something with the drivers.
73 Phil NC3S
on the usb port, some just provide power, not signal.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
