FlexRadio and Heil mic?
sp8s
Hi
I have older Heil mic - GM-4 the gold series, with Icom's plug. Is there a way to use it with Flex?
Stan SP8S
Stan SP8S
Hi Stan,
Since this GM4 is a dynamic microphone, it should work with Flex without any problems.
Only the plug needs to be changed, as these multipole plugs are not usable with FlexRadio.The microphone has an 4-Pin XLR connector and the 8000 FlexRadio series has a TRS 6,3 mm jack
Ready-made cables for this are available in music stores.
73, Klaus0 -
Hi Klaus, thanks so much for your valuable advice!
All the best of greetings
73! Stan SP8S
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
