GNSS question
Using an 8600M.
yes. I use a 15 ft SMA male to female I bought on Amazon.
73 Dave wo2x
So I have tried the GNSS dongle in 3 different locations in the shack, with no joy. I have another radio which its GPS dongle connects fairly quickly and a WSPR transmitter that connects almost immediately. ( BTW It seemed like GNSS did connect occasionally when I first got 8600 and before latest firmware update)
So any suggestions?
Should I but an extension cable mentioned earlier and get closer to window?
running V 4.1.5 on a Win 11 pc.
73 Paul w2eck
Closer to windows will definitely help depending on which direction they face. The short time I had a 8600M before returning it, I put the GNSS receiver in a northwest facing window. It didn't take long for it to find and lock on to several satellites. But, if I just sat it on a shelf above the table my radio was sitting on, it rarely would get a lock.
I just ordered an 18 ft extension cable - we'll see if that helps. thanks for response.
Still curious why the GNSS dongle doesn't connect and my others do sitting on same desktop?
73 Paul w2eck
Part of the problem might be the difference between the different satellite systems being used with your other equipment. GNSS ,if I remember correctly, uses a different set of satellites than other GPS systems.
Well that helps understand - thanks
73 Paul w2eck
Got the extension cable - that solved my problem = have at the window now and connects quite quickly
Tnx for the help
73 Paul w2eck
@Trucker said: GNSS ,if I remember correctly, uses a different set of satellites than other GPS systems.
Yes.
GNSS (Global Navigation Satellite System) = GLONASS = Russian
GPS is a subset of GNSS.
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
