How to fix the blinking green button issue? (Flex doesn't turn on)
Hi, I just received my 8600 and when I try to turn it on, its power button is blinking green and nothing happens. Looks like it doesn't turn on in 100% or has some firmware issues. The radio is undetectable in the LAN network, and nothing happens next.
Anyone experienced something like that and any suggestions how to fix that?
I'd be thankful for any advices.
73 de Stan SP8S
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    With most of these odd issues, a “factory reset” is a starting point. Press and hold the power button until it turns while.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    I think John meant '….turns white' :-)
    Sten… If the 'factory reset' doesn't resolve the problem, please open a Help Desk Ticket. Blinking green is a normal part of the boot up sequence, but it sounds like your rig isn't completing the boot up sequence.
  • John KB4DU
    Thanks! Auto-corrupt is working.
  • sp8s
    sp8s Member ✭✭
    Thanks for all answers, guys! Sadly, the factory reset didn't help and once I explained what's going on at WiMo (the store I bought it at), they immediately created a return label, and it seems the unit is going to be replaced. Btw, I highly recommend the store. Top-notch customer service and superfast response. This is how things are to be done to make customers happy!
    73!
    Stan SP8S
