Using Autotune CW on Maestro
For Maestro, the AutoTune feature is in the Slice Menu on the top right side (in CW mode, of course):
Unfortunately, the assignment of Autotune to an F key is lost every time the Maestro is turned off. Hopefully, this bug will be fixed as soon as possible!
Thanks for pointing out this bug. We are tracking this as SMART-12135 and will get this fixed up in a future release.
In SmartSDR v4.15, there’s a lock icon over Autotune and Oneshot—does this mean a newer paid version is needed to unlock them? Another issue is that when N1MM is sending CW, using the hand keyer causes both keying sources to mix. The paddle connected to the Maestro doesn’t interrupt or take over the automatic keying from N1MM. On the plus side, the Maestro tone issue is fixed in v4.15, but this problem is still pretty annoying.0
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
