boot time
DonE
My 6400 takes 2 minute to boot now which is an increase from a minute is this is a sign of problem or not
In early January, the same thing happened on my 6600. Boot time went from about 35 seconds to 100 seconds. I was on v3.7.4 that had been running well. When I upgraded to 4.1.5, boot time returned to about 35 seconds. My guess is something changed in the process where the radio registers with the Smartlink server.
under the search facility at the top of this forum, search for “slow boot time” . You will find you are not alone, and that a bit of patience is required together with maybe a couple of hards resets, and you will be ok again
73 Mike
THANKS
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
