boot time
DonE
DonE Member ✭✭
edited January 14 in SmartSDR for Windows
My 6400 takes 2 minute to boot now which is an increase from a minute is this is a sign of problem or not
  • Jeff_W4DD
    Jeff_W4DD Member ✭✭
    In early January, the same thing happened on my 6600. Boot time went from about 35 seconds to 100 seconds. I was on v3.7.4 that had been running well. When I upgraded to 4.1.5, boot time returned to about 35 seconds. My guess is something changed in the process where the radio registers with the Smartlink server.
  • Mike Steventon
    Mike Steventon Member ✭✭✭
    under the search facility at the top of this forum, search for “slow boot time” . You will find you are not alone, and that a bit of patience is required together with maybe a couple of hards resets, and you will be ok again
    73 Mike
  • DonE
    DonE Member ✭✭
    THANKS
