Can someone help with MRP40
Bru
I am another MRP40 user, a registered one who paid for the program and was using it with my Icom 7300. But on moving up to a Flex 6400 am having difficulties getting it to work completely. I do believe I am almost 90% of the way there and it IS decoding CW perfectly, and it is also sending to the radio, because I can clearly see the signals coming into the TX Stream in my DAX. I created a new COM port COM5, using smart SDRCat and assigned it to MRP40. The only problem I am having it it will not put the radio into transmit with PTT. So sound in is working and decoding, sound out is working and I can see it in the TX stream. Both levels are clearly working and adjustable with the DAX level controls and I have a connected com port, just no PTT to ask the radio to transmit. Can anyone help me with this because I believe I am close. Previous comments said it would not decode properly with a Flex, but that part is working perfectly. Thanks All:-)
Hi Bruce,
I think you want to do CW and not transmit the CW audio tone in SSB over DAX.
To do this, your configuration needs to be slightly different.
First, a Winkeyer must be created in SmartCat.Then set WinKey as the send option in MRP.
and switch to bug mode!
vy73 55 Klaus2 -
Klaus.....thank you so much for helping me with this.Got it working perfectly this morning. I believe this will help a lot of people with Flex Radios, that have this program and cannot get it working.
Bruce KO4UHL2
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
