Can someone help with MRP40
I am another MRP40 user, a registered one who paid for the program and was using it with my Icom 7300. But on moving up to a Flex 6400 am having difficulties getting it to work completely. I do believe I am almost 90% of the way there and it IS decoding CW perfectly, and it is also sending to the radio, because I can clearly see the signals coming into the TX Stream in my DAX. I created a new COM port COM5, using smart SDRCat and assigned it to MRP40. The only problem I am having it it will not put the radio into transmit with PTT. So sound in is working and decoding, sound out is working and I can see it in the TX stream. Both levels are clearly working and adjustable with the DAX level controls and I have a connected com port, just no PTT to ask the radio to transmit. Can anyone help me with this because I believe I am close. Previous comments said it would not decode properly with a Flex, but that part is working perfectly. Thanks All:-)
  • KlausP
    KlausP Member ✭✭
    edited January 13
    Hi Bruce,
    I think you want to do CW and not transmit the CW audio tone in SSB over DAX.
    To do this, your configuration needs to be slightly different.
    First, a Winkeyer must be created in SmartCat.
    Then set WinKey as the send option in MRP.
    and switch to bug mode!
    vy73 55 Klaus
  • Bru
    Bru Member ✭✭
    Klaus.....thank you so much for helping me with this.Got it working perfectly this morning. I believe this will help a lot of people with Flex Radios, that have this program and cannot get it working.
    Bruce KO4UHL
