MOX Hangs After DVK Message
I recorded a couple of messages using the DVK feature of my 8600. After recording them, I used Audacity to adjust the volume and trim the leading and trailing portions off each message. I then uploaded these messages back to my 8600.
The messages play correctly when I press the "F" keys, but the transceiver does not return to receive; MOX stays on after the message is sent.
Pressing the MOX button after the DVK message plays returns the transceiver to receive mode.
If I turn the VOX off, the messages play as expected, and the transceiver returns to receive.
Is it possible to enable VOX while using the DVK simultaneously?
Hi,
check what time is displayed for the file in DVK. It's possible that the shortened file isn't actually shortened.
If you set an end mark in your Audio software and save the file may be the old length will be retained.
Only if you save the selected area will the time be shortened.
At least that's how it works for me. But I use Goldwave
73 Klaus0 -
Klaus,
Thanks for the tip. I rerecorded all of my messages and made sure to save only the audio I wanted. The DVK is working properly!
Howard N8HO
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
