Interlock is preventing transmission amp:tgxl
Eric and Lacy, what are the stars in your comments? Brand names? Cuss words? Curious for future reference. Thanks
Laci, in a contest, the fastest most reliable method I have found is to cut off the power to the TGXL for a few seconds then power it back on.
I checked my delays and the Genius Integration Tab.
I sure hope my Flex Radio Dream Station works today. I am W1AW/0 on 6 bands. It would be a shame if it didn't work.
Well it looks like this forum censors the use of the term '****'. Guess I should have said 'secondary'. :)
I was attempting to use my DXE 2x8 antenna switch with custom software for the relay controller that acted as a secondary faux-AG to a primary AG I had acquired along with the TG. That would give me a 2x14 switch using the AG stacking mode that uses antenna 7 & 8 to connect to the secondary switch.
Eric - NR4O0 -
Anybody hear any more since the last post? Seems ridiculous that you uncheck PGXL on the Genius "Integration" Tab, but I did it. Here's the last I heard from them. Pretty sure I shouldn't have to pay to have this addressed…
I am going to ask Dave De **** to look at this. He is our resident expert on TGXL interfacing with Flex Radios. He may need to schedule a Paid FlexAdvantage session to log in to your computer and look at things.
Paul, the PG CL checkbox in Genius Integration is only required for non-Flex transceivers. Checking it allows CAT from OEM radio to PG then PG sends band and frequency data to the TG over the LAN.
In a Flex/4O3A environment communications between PG and TG are over the LAN when both have the Flex defined in the Flex tab in both apps.
This is covered in the Flex Dream Station configuration guide.
https://helpdesk.flexradio.com/hc/en-us/articles/20826281594011-Configuring-the-Dream-Station-FLEX-8000-6000-with-the-PGXL-TGXL-AG-for-Proper-Operation
73 Dave wo2x0 -
The function of the checkbox in Genius Integration is not clear. While it is spelled out in some of the documentation, the checkbox should state explicitly when it is to be used. It would aleviate confusion.
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 142 Amateur Radio Interests
