Smart SDR 4.1.5 will not find 6400 on my network
The previous software I had worked perfectly tried downloading 4.1.5 and installing and it will not show my 6400. There do nto seem to be any posts here for 4.1.5 so I'm not sure how to get help in correcting this
Tried to go back to smart sdr 3.7.3 my previous version and it still will not connect to my radio. This is all messed up. I'm not sure what to do to be back on the air. Read through the notes a couple of times I just must not understand something.
Did you import your old Profiles? This seems to cause a lot of problems. Also if you haven't done so, you should do a full factory reset. Power off the radio. Then disconnect the power supply for a few minutes. Reconnect the power supply. Press the power button on the radio and hold till the button back light turns white. Let go and let the radio do it's thing and reset. Once if finishes, power off. Let the radio sit a couple of minutes again and then power it up as normal. Once it boots up start SmartSDR and it should find your radio. If not, try a direct connection between the radio and your computer to rule out a network problem.
I had the same problem, exported profiles and also unchecked "preferences at the bottom of
export page. It nows works fine. Setup new profiles also.
Don…w2xb
The Reset Process Worked. I tried this previously and it didn't help. It worked this time.
Thanks 73
It would be good to have a manual and I still would like to have sliders for various NR settings. as a ham I like to be able to experiment with settings. It just a ham thing.
thanks 73
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
