AGC-T ?
W2ECK
Member ✭✭✭
So another question regarding AGC-T settings. So as per a paper Tim did on finding the knee of the curve in setting your AGC-T level. I do that in CW mode, (setting is on Fast) . But once I find the "knee" level, the software then keeps changing the level - usually upward.
So what am I missing or doing wrong? Or maybe just don't understand the procedure fully?
73 Paul w2eck
Hi Paul,
Which software are you referring to that's resetting your AGC-T after you find the knee ? Never seen that happen here.
GL Russ KR6W
Hi Paul, if you are using SDC, that is the likely culprit. It will optionally adjust your AGC-T and/or your noise floor level.
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
